      statistics preset modify
Modify an existing Performance Preset
Modifies an existing performance preset configuration. The command modifies the global properties of a preset, but does not modify the details of the preset, such as specific objects and counters sampled.
- -preset <text>- Preset Name (privilege: advanced)
Name of the performance preset to be modified.
- [-new-name <text>]- New Preset Name (privilege: advanced)
Set preset name to the given new name.
- [-comment <text>]- Preset Description (privilege: advanced)
Set comment to the given value.
- [-privilege <PrivilegeLevel>]- Preset Privilege Level (privilege: advanced)
Set privilege level at which this preset can be viewed or modified to the given value. Possible values: admin, advanced, diagnostic.
cluster1::*> statistics preset show
       Preset Name: delta
       Preset UUID: 7a04f19d-02a7-11e2-8e40-123478563412
           Comment: custom preset description
         Privilege: diagnostic
         Read-Only: false
   Archive Enabled: false
     Generation ID: 0
1 entry was displayed.
cluster1::*> statistics preset modify -preset delta -comment "new comment"
       Preset Name: delta
           Comment: new comment
         Read-Only: false
     Generation ID: 0
 PDFs
PDFs
