statistics preset modify
PDF of this doc site
Creating your file...
Your file is ready
Modify an existing Performance Preset
Modifies an existing performance preset configuration. The command modifies the global properties of a preset, but does not modify the details of the preset, such as specific objects and counters sampled.
-preset <text>
- Preset Name (privilege: advanced)-
Name of the performance preset to be modified.
[-new-name <text>]
- New Preset Name (privilege: advanced)-
Set preset name to the given new name.
[-comment <text>]
- Preset Description (privilege: advanced)-
Set comment to the given value.
[-privilege <PrivilegeLevel>]
- Preset Privilege Level (privilege: advanced)-
Set privilege level at which this preset can be viewed or modified to the given value. Possible values: admin, advanced, diagnostic.
cluster1::*> statistics preset show Preset Name: delta Preset UUID: 7a04f19d-02a7-11e2-8e40-123478563412 Comment: custom preset description Privilege: diagnostic Read-Only: false Archive Enabled: false Generation ID: 0 1 entry was displayed. cluster1::*> statistics preset modify -preset delta -comment "new comment" cluster1::*> statistics preset show Preset Name: delta Preset UUID: 7a04f19d-02a7-11e2-8e40-123478563412 Comment: new comment Privilege: diagnostic Read-Only: false Archive Enabled: false Generation ID: 0 1 entry was displayed.
