The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system services ndmp service stop
PDF of this doc site
Creating your file...
Your file is ready
Stop the NDMP service
The system services ndmp service stop
command stops the NDMP service daemon on a node. This is a disruptive command and should not be used in normal scenarios. Processing of active sessions continues but the ability to view or kill sessions is lost. This is different from the system services ndmp off command. The system services ndmp off command disables new NDMP connections on the node but does not stop the NDMP service daemon.
-node {<nodename>|local}
- Node (privilege: advanced)-
The node on which the NDMP service needs to be stopped.
cluster1::*> system services ndmp service stop -node node0
Stops the NDMP service on node0.
