volume flexcache config-refresh
PDF of this doc site
Creating your file...
Your file is ready
Refresh FlexCache configuration for a peer volume
The `volume flexcache config-refresh` command is used to refresh the FlexCache configuration. It can be used to update the configuration on either the FlexCache or origin of a FlexCache cluster. This command only needs to be run if the automatic refresh failed and the corresponding EMS was generated.
This command must be run on the peer cluster. For example, refresh of origin of a FlexCache volume must be run from the FlexCache cluster. Refresh a FlexCache volume must be run from the of an origin of a FlexCache cluster. |
-peer-vserver <vserver name>
- Peer Vserver (privilege: advanced)-
Name of the Vserver for which the configuration is being refreshed.
-peer-volume <volume name>
- Peer Volume (privilege: advanced)-
Name of the volume for which the configuration is being refreshed.
-peer-endpoint-type {cache|origin}
- Origin/Cache Volume (privilege: advanced)-
The peer-endpoint-type specifies the FlexCache endpoint type of the peer volume. Possible values are
cache
for FlexCache volumes andorigin
for origin of a FlexCache volumes.
The following example triggers config-refresh on origin of a FlexCache volume "origin1".
cluster1::> flexcache config-refresh -peer-vserver vs34 -peer-volume origin1 -peer-endpoint-type origin (volume flexcache config-refresh)
The following example triggers config-refresh on FlexCache volume "fc1".
cluster1::> flexcache config-refresh -peer-vserver vs34 -peer-volume fc1 -peer-endpoint-type cache (volume flexcache config-refresh)
The following example triggers config-refresh on FlexCache volume "fc1" with an incorrect peer-endpoint-type.
cluster1::> flexcache config-refresh -peer-vserver vs34 -peer-volume fc1 -peer-endpoint-type origin (volume flexcache config-refresh) Error: command failed: Failed to store the configuration for peer volume "fc1" in Vserver "vs34" on cluster "cluster1". Check the FlexCache configuration on the local cluster and retry the operation.
