volume flexcache config-refresh
Refresh FlexCache configuration for a peer volume
The `volume flexcache config-refresh` command is used to refresh the FlexCache configuration. It can be used to update the configuration on either the FlexCache or origin of a FlexCache cluster. This command only needs to be run if the automatic refresh failed and the corresponding EMS was generated.
NOTE:
This command must be run on the peer cluster. For example, refresh of origin of a FlexCache volume must be run from the FlexCache cluster. Refresh of a FlexCache volume must be run from the origin of a FlexCache cluster.
-peer-vserver <vserver name>- Peer Vserver (privilege: advanced)-
Name of the Vserver for which the configuration is being refreshed.
-peer-volume <volume name>- Peer Volume (privilege: advanced)-
Name of the volume for which the configuration is being refreshed.
-peer-endpoint-type {cache|origin}- Origin/Cache Volume (privilege: advanced)-
The peer-endpoint-type specifies the FlexCache endpoint type of the peer volume. Possible values are
cachefor FlexCache volumes andoriginfor origin of a FlexCache volumes.
The following example triggers config-refresh on origin of a FlexCache volume "origin1".
cluster1::> flexcache config-refresh -peer-vserver vs34 -peer-volume origin1 -peer-endpoint-type origin
(volume flexcache config-refresh)
The following example triggers config-refresh on FlexCache volume "fc1".
cluster1::> flexcache config-refresh -peer-vserver vs34 -peer-volume fc1 -peer-endpoint-type cache
The following example triggers config-refresh on FlexCache volume "fc1" with an incorrect peer-endpoint-type.
cluster1::> flexcache config-refresh -peer-vserver vs34 -peer-volume fc1 -peer-endpoint-type origin
Error: command failed: Failed to store the configuration for peer volume "fc1"
in Vserver "vs34" on cluster "cluster1". Check the FlexCache
configuration on the local cluster and retry the operation.
