ONTAP commands
storage tape alias show
Displays aliases of all tape drives and media changers
This command displays aliases of all tape drives and media changers attached to every node in the cluster.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Displays the tape drive and media changer aliases on the specified node.
[-alias-list <text>,…​] - List of Aliases
Displays the node with the specified list of tape drive and media changer aliases.
The following example shows the aliases of all tape drives and media changers attached to every node in the cluster:
cluster1::> storage tape alias show
Node: node1
Alias                                   Mapping
mc0                                     SN[00FRU7800000_LL0]L1
mc1                                     SN[00FRU7800000_LL1]L1
mc2                                     SN[aa6a64c69360a0980248c8]
mc3                                     SN[c940abe8b0c3a0980248c8]
mc4                                     SN[fba082e6b335a0980248c8]L5
st0                                     SN[HU19487T7N]
st1                                     SN[1068000230]
st10                                    SN[fba0c508b335a0980248c8]L7
Node: node2
Alias                                   Mapping
mc1                                     SN[c940982fc48c8]
st3                                     SN[ST456HT8N]L3
st2                                     SN[HG68000230]L2
st11                                    SN[aba673980248c8]L7
