The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
metrocluster transition enable
PDF of this doc site
Creating your file...
Your file is ready
Enable Transition
The metrocluster transition enable
command is used to start the transition from a MetroCluster FC to a MetroCluster IP configuration. The command sets the transition mode on the local and partner cluster.
-transition-mode <Mode For FC To Ip Transition>
- Transition Mode (privilege: advanced)-
This parameter specifies the setting for the transition-mode.
[-force {true|false}]
- Force enable (privilege: advanced)-
This optional parameter forces the setting for the transition-mode.
The following example shows how to enable the non-disruptive transition mode:
clusA::> metrocluster transition enable transition-mode non-disruptive clusA::> metrocluster transition show-mode Transition Mode -------------------------- non-disruptive
The following example shows how to enable the disruptive transition mode:
clusA::> metrocluster transition enable transition-mode disruptive clusA::> metrocluster transition show-mode Transition Mode -------------------------- disruptive
