ONTAP 9.13.1 commands
vserver nvme subsystem modify
Modify an NVMe target subsystem
The vserver nvme subsystem modify command modifies an existing NVMe target subsystem.
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver.
-subsystem <text> - Subsystem
Specifies the NVMe target subsystem.
[-comment <text>] - Comment
Contains a textual description of the NVMe subsystem.
[-delete-on-unmap {true|false}] - Delete on Unmap (privilege: advanced)
Specifies whether the subsystem should be deleted automatically when it is no longer mapped to a namespace.
cluster1::*> vserver nvme subsystem modify -vserver vs_1 -subsystem sub_1 -comment "Example Comment"
Modifies the comment on the subsystem named sub_1 on Vserver vs_1 .
