vserver http-proxy show
PDF of this doc site
Creating your file...
Display HTTP Proxy configuration
The vserver http-proxy show
command displays information about HTTP proxy configurations. The IPspace field is populated only if a Vserver is the system vserver of that IPspace. For all other Vservers, the IPspace field is empty.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. - {
[-vserver <vserver>]
- Vserver -
Use this parameter to display information only about the HTTP proxy configuration of the Vservers you specify.
[-ipspace <text>]
- Ipspace-
Use this parameter to display information only about the HTTP proxy configuration of the IPspace you specify.
[-server <text>]
- Proxy Server-
Use this parameter to display information only about the HTTP proxy configurations that match the the Fully Qualified Domain Name or IP address you specify.
[-port <integer>]
- Port-
Use this parameter to display information only about the HTTP proxy configurations that match the port you specify.
[-is-auth-enabled {true|false}]
- Authentication Enabled-
Use this parameter to display information only about the HTTP proxy configurations that match the specified authentication enabled setting.
The following example displays information about all HTTP proxy configurations:
cluster1::*> vserver http-proxy show Vserver IPSpace Server Port --------------- -------------- ---------------------------------- ---------------- test test 10.0.0.0 3128 vs2 - 192.168.0.0 3128 2 entries were displayed.
The following example displays information about all HTTP proxy configurations with server
10.0.0.0:
cluster1::*> vserver http-proxy show -server 10.0.0.0 Vserver IPSpace Server Port --------------- -------------- ---------------------------------- ---------------- test test 10.0.0.0 3128
