ONTAP commands
vserver http-proxy show
Display HTTP Proxy configuration
The vserver http-proxy show command displays information about HTTP proxy configurations. The IPspace field is populated only if a Vserver is the system vserver of that IPspace. For all other Vservers, the IPspace field is empty.
{ [-fields <fieldname>,…​]
| [-instance ] }
{ [-vserver <vserver>] - Vserver
Use this parameter to display information only about the HTTP proxy configuration of the Vservers you specify.
[-ipspace <text>] - Ipspace
Use this parameter to display information only about the HTTP proxy configuration of the IPspace you specify.
[-server <text>] - Proxy Server
Use this parameter to display information only about the HTTP proxy configurations that match the the Fully Qualified Domain Name or IP address you specify.
[-port <integer>] - Port
Use this parameter to display information only about the HTTP proxy configurations that match the port you specify.
[-is-auth-enabled {true|false}] - Authentication Enabled
Use this parameter to display information only about the HTTP proxy configurations that match the specified authentication enabled setting.
The following example displays information about all HTTP proxy configurations:
cluster1::*> vserver http-proxy show
Vserver         IPSpace        Server                             Port
test            test           10.0.0.0                           3128
vs2             -              192.168.0.0                        3128
2 entries were displayed.
The following example displays information about all HTTP proxy configurations with server 10.0.0.0:
cluster1::*> vserver http-proxy show -server 10.0.0.0
