storage aggregate offline
Offline an aggregate
The storage aggregate offline
command takes an aggregate offline.
If you are taking a root aggregate offline, the node owning the aggregate must be in maintenance mode.
-aggregate <aggregate name>
- Aggregate-
The name of the aggregate to be taken offline.
The following example takes an aggregate named aggr1 offline:
cluster1::> storage aggregate offline -aggregate aggr1
