      vserver vscan reset
Discard cached scan information
The vserver vscan reset command discards the cached information of the files that have been successfully scanned. After running this command, the files are scanned again when they are accessed.
- -vserver <vserver name>- Vserver
This parameter specifies the name of the Vserver for which you want to discard the cached information.
The following example discards the cached information of the successfully scanned files.
cluster1::> vserver vscan reset -vserver vs1
Warning: Running this command can cause performance degradation because files are scanned again when they are accessed.
Do you want to continue? {y|n}: y
cluster1::>
 PDFs
PDFs
