The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver vscan reset
PDF of this doc site
Creating your file...
Your file is ready
Discard cached scan information
The vserver vscan reset
command discards the cached information of the files that have been successfully scanned. After running this command, the files are scanned again when they are accessed.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver for which you want to discard the cached information.
The following example discards the cached information of the successfully scanned files.
cluster1::> vserver vscan reset -vserver vs1 Warning: Running this command can cause performance degradation because files are scanned again when they are accessed. Do you want to continue? {y|n}: y cluster1::>
