ONTAP commands
security certificate print
Display the contents of a certificate
This command displays the details of either an installed certificate or by reading a certificate from user input.
-vserver <Vserver Name> - Vserver Name
Use this parameter to specify the Vserver that has the certificate installed.
{ [-cert-name <text>] - Installed Certificate Name
Use this parameter to specify the unique name of the installed certificate to read and display.
| [-cert-uuid <UUID>] - Installed Certificate UUID }
Use this parameter to specify the unique UUID of the installed certificate to read and display. With no name or UUID specified, the certificate will read and display from user input.
The following example reads and prints the details of the certificate.
cluster1::> security certificate print -vserver vs0 -cert-name AAACertificateServices
Certificate details:
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number: 6271844772424770508 (0x570a119742c4e3cc)
    Signature Algorithm: sha256WithRSAEncryption
        Issuer: C=IT, L=Milan, O=Actalis S.p.A./03358520967, CN=Actalis
Authentication Root CA
        Validity
            Not Before: Sep 22 11:22:02 2011 GMT
            Not After : Sep 22 11:22:02 2030 GMT
        Subject: C=IT, L=Milan, O=Actalis S.p.A./03358520967, CN=Actalis
        Subject Public Key Info:
            Public Key Algorithm: rsaEncryption
                Public-Key: (4096 bit)
                Modulus:
                    00:a7:c6:c4:a5:29:a4:2c:ef:e5:18:c5:b0:50:a3:
                    6f:51:3b:9f:0a:5a:c9:c2:48:38:0a:c2:1c:a0:18:
                    7f:91:b5:87:b9:40:3f:dd:1d:68:1f:08:83:d5:2d:
                    1e:88:a0:f8:8f:56:8f:6d:99:02:92:90:16:d5:5f:
                    08:6c:89:d7:e1:ac:bc:20:c2:b1:e0:83:51:8a:69:
                    4d:00:96:5a:6f:2f:c0:44:7e:a3:0e:e4:91:cd:58:
                    ee:dc:fb:c7:1e:45:47:dd:27:b9:08:01:9f:a6:21:
                    1d:f5:41:2d:2f:4c:fd:28:ad:e0:8a:ad:22:b4:56:
                    65:8e:86:54:8f:93:43:29:de:39:46:78:a3:30:23:
                    ba:cd:f0:7d:13:57:c0:5d:d2:83:6b:48:4c:c4:ab:
                    9f:80:5a:5b:3a:bd:c9:a7:22:3f:80:27:33:5b:0e:
                    b7:8a:0c:5d:07:37:08:cb:6c:d2:7a:47:22:44:35:
                    c5:cc:cc:2e:8e:dd:2a:ed:b7:7d:66:0d:5f:61:51:
                    22:55:1b:e3:46:e3:e3:3d:d0:35:62:9a:db:af:14:
                    c8:5b:a1:cc:89:1b:e1:30:26:fc:a0:9b:1f:81:a7:
                    47:1f:04:eb:a3:39:92:06:9f:99:d3:bf:d3:ea:4f:
                    50:9c:19:fe:96:87:1e:3c:65:f6:a3:18:24:83:86:
                    10:e7:54:3e:a8:3a:76:24:4f:81:21:c5:e3:0f:02:
                    f8:93:94:47:20:bb:fe:d4:0e:d3:68:b9:dd:c4:7a:
                    84:82:e3:53:54:79:dd:db:9c:d2:f2:07:9b:2e:b6:
                    bc:3e:ed:85:6d:ef:25:11:f2:97:1a:42:61:f7:4a:
                    97:e8:8b:b1:10:07:fa:65:81:b2:a2:39:cf:f7:3c:
                    ff:18:fb:c6:f1:5a:8b:59:e2:02:ac:7b:92:d0:4e:
                    14:4f:59:45:f6:0c:5e:28:5f:b0:e8:3f:45:cf:cf:
                    af:9b:6f:fb:84:d3:77:5a:95:6f:ac:94:84:9e:ee:
                    bc:c0:4a:8f:4a:93:f8:44:21:e2:31:45:61:50:4e:
                    10:d8:e3:35:7c:4c:19:b4:de:05:bf:a3:06:9f:c8:
                    b5:cd:e4:1f:d7:17:06:0d:7a:95:74:55:0d:68:1a:
                    fc:10:1b:62:64:9d:6d:e0:95:a0:c3:94:07:57:0d:
                    14:e6:bd:05:fb:b8:9f:e6:df:8b:e2:c6:e7:7e:96:
                    f6:53:c5:80:34:50:28:58:f0:12:50:71:17:30:ba:
                    e6:78:63:bc:f4:b2:ad:9b:2b:b2:fe:e1:39:8c:5e:
                    ba:0b:20:94:de:7b:83:b8:ff:e3:56:8d:b7:11:e9:
                    3b:8c:f2:b1:c1:5d:9d:a4:0b:4c:2b:d9:b2:18:f5:
                    b5:9f:4b
                Exponent: 65537 (0x10001)
        X509v3 extensions:
            X509v3 Subject Key Identifier:
                52:D8:88:3A:C8:9F:78:66:ED:89:F3:7B:38:70:94:C9:02:02:36:D0
            X509v3 Basic Constraints: critical
                CA:TRUE
            X509v3 Authority Key Identifier:
keyid:52:D8:88:3A:C8:9F:78:66:ED:89:F3:7B:38:70:94:C9:02:02:36:D0
X509v3 Key Usage: critical
                Certificate Sign, CRL Sign
         0b:7b:72:87:c0:60:a6:49:4c:88:58:e6:1d:88:f7:14:64:48:
         a6:d8:58:0a:0e:4f:13:35:df:35:1d:d4:ed:06:31:c8:81:3e:
         6a:d5:dd:3b:1a:32:ee:90:3d:11:d2:2e:f4:8e:c3:63:2e:23:
         66:b0:67:be:6f:b6:c0:13:39:60:aa:a2:34:25:93:75:52:de:
         a7:9d:ad:0e:87:89:52:71:6a:16:3c:19:1d:83:f8:9a:29:65:
         be:f4:3f:9a:d9:f0:f3:5a:87:21:71:80:4d:cb:e0:38:9b:3f:
         bb:fa:e0:30:4d:cf:86:d3:65:10:19:18:d1:97:02:b1:2b:72:
         42:68:ac:a0:bd:4e:5a:da:18:bf:6b:98:81:d0:fd:9a:be:5e:
         15:48:cd:11:15:b9:c0:29:5c:b4:e8:88:f7:3e:36:ae:b7:62:
         fd:1e:62:de:70:78:10:1c:48:5b:da:bc:a4:38:ba:67:ed:55:
         3e:5e:57:df:d4:03:40:4c:81:a4:d2:4f:63:a7:09:42:09:14:
         fc:00:a9:c2:80:73:4f:2e:c0:40:d9:11:7b:48:ea:7a:02:c0:
         d3:eb:28:01:26:58:74:c1:c0:73:22:6d:93:95:fd:39:7d:bb:
         2a:e3:f6:82:e3:2c:97:5f:4e:1f:91:94:fa:fe:2c:a3:d8:76:
         1a:b8:4d:b2:38:4f:9b:fa:1d:48:60:79:26:e2:f3:fd:a9:d0:
         9a:e8:70:8f:49:7a:d6:e5:bd:0a:0e:db:2d:f3:8d:bf:eb:e3:
         a4:7d:cb:c7:95:71:e8:da:a3:7c:c5:c2:f8:74:92:04:1b:86:
         ac:a4:22:53:40:b6:ac:fe:4c:76:cf:fb:94:32:c0:35:9f:76:
         3f:6e:e5:90:6e:a0:a6:26:a2:b8:2c:be:d1:2b:85:fd:a7:68:
         c8:ba:01:2b:b1:6c:74:1d:b8:73:95:e7:ee:b7:c7:25:f0:00:
         4c:00:b2:7e:b6:0b:8b:1c:f3:c0:50:9e:25:b9:e0:08:de:36:
         66:ff:37:a5:d1:bb:54:64:2c:c9:27:b5:4b:92:7e:65:ff:d3:
         2d:e1:b9:4e:bc:7f:a4:41:21:90:41:77:a6:39:1f:ea:9e:e3:
         9f:d0:66:6f:05:ec:aa:76:7e:bf:6b:16:a0:eb:b5:c7:fc:92:
         54:2f:2b:11:27:25:37:78:4c:51:6a:b0:f3:cc:58:5d:14:f1:
         6a:48:15:ff:c2:07:b6:b1:8d:0f:8e:5c:50:46:b3:3d:bf:01:
         98:4f:b2:59:54:47:3e:34:7b:78:6d:56:93:2e:73:ea:66:28:
         78:cd:1d:14:bf:a0:8f:2f:2e:b8:2e:8e:f2:14:8a:cc:e9:b5:
         7c:fb:6c:9d:0c:a5:e1:96
