qos workload delete
Delete workload
Deletes a workload from a cluster. When you delete a workload, the associated data object is no longer controlled by its policy group.
You can only delete user-defined workloads. You cannot delete system-defined or preset workloads.
-workload <text>- Workload Name-
Specifies the name of the workload that you want to delete.
cluster1::> qos workload delete workload1
Deletes the "workload1" user-defined workload from the "cluster1" cluster.
