The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
lun import verify stop
PDF of this doc site
Creating your file...
Your file is ready
Stop the verify for the specified LUN
This command stops the block by block verification of the foreign disk and LUN data.
-vserver <Vserver Name>
- Vserver Name (privilege: advanced)-
Specifies the Vserver that contains the LUN you want to stop block by block comparison with the foreign disk.
-path <path>
- LUN Path (privilege: advanced)-
Specifies the path of the LUN that you want to stop the block by block comparison. Examples of correct LUN paths are
/vol/vol1/lun1
and/vol/vol1/qtree1/lun1
cluster1::> lun import verify stop -vserver vs1 -path /vol/vol2/lun2
Stops the import verify on lun at path /vol/vol2/lun2.
