The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
storage stackmon repair run
PDF of this doc site
Creating your file...
Your file is ready
Repair stackmon
The storage stackmon repair run
command diagnoses stackmon reconciliation failures and attempts to repair the stack IDs.
[-skip-check-stackmon-state <true>]
- Skip Check for Stackmon State (privilege: advanced)-
This parameter allows the command to be executed when stackmon is still running.
The following example diagnoses and repairs the stack IDs following a stackmon reconciliation failure.
cluster1::*> storage stackmon repair run
