ONTAP commands
storage stackmon repair run
Repair stackmon
The storage stackmon repair run command diagnoses stackmon reconciliation failures and attempts to repair the stack IDs.
[-skip-check-stackmon-state <true>] - Skip Check for Stackmon State (privilege: advanced)
This parameter allows the command to be executed when stackmon is still running.
The following example diagnoses and repairs the stack IDs following a stackmon reconciliation failure.
cluster1::*> storage stackmon repair run
