      system configuration backup settings clear-password
Clear password for destination URL
The `system configuration backup settings clear-password ` command clears the password used for uploads of configuration backups. Enter the command without parameters.
Use the system configuration backup settings show command to display the destination URL for configuration backups. Use the system configuration backup settings modify command to change the destination URL and remote username for configuration backups.
The following example shows successful execution of this command.
cluster1::*> system configuration backup settings clear-password
Do you want to clear the password? {y|n}:
 PDFs
PDFs
