system services ndmp modify
PDF of this doc site
Creating your file...
(DEPRECATED)-Modify NDMP service configuration
This node-scoped NDMP command is deprecated. Node-scoped NDMP functionality may be removed in a future release of Data ONTAP. Use the Vserver-aware "vserver services ndmp modify " command. |
The system services ndmp modify
command allows you to modify the NDMP configurations for a node in the cluster. One or more of the following configurations can be modified:
Enable/disable NDMP service
Enable/disable sending the NDMP password in clear text. Note that MD5 authentication mode is always enabled.
NDMP user ID
-node {<nodename>|local}
- Node-
This specifies the node whose NDMP configuration is to be modified.
[-enable {true|false}]
- NDMP Service Enabled-
This optionally specifies whether NDMP is enabled on the node. The default setting is
true
. [-clear-text {true|false}]
- Allow Clear Text Password-
This optionally specifies whether the NDMP password can be sent in clear text. The default setting is
true
. [-user-id <text>]
- NDMP User ID-
This optionally specifies the ID of the NDMP user.
The following example modifies the NDMP configuration on a node named node1. The configuration enables NDMP, disables sending the password in clear text, and specifies an NDMP user named ndmp:
cluster1::> system services ndmp modify -node node1 -enable true -clear-text false -user-id ndmp
