vserver nvme delete
PDF of this doc site
Creating your file...
Your file is ready
Delete NVMe service configuration
The vserver nvme delete
command deletes an NVMe service of a Vserver. Before you can delete an NVMe service, the administrative status must be down
. Use the vserver nvme modify command to change the administrative status.
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver for the NVMe service.
cluster1::*> vserver nvme delete -vserver vs_1
Deletes the NVMe service on Vserver vs_1
