ONTAP commands
vserver nvme delete
Delete NVMe service configuration
The vserver nvme delete command deletes an NVMe service of a Vserver. Before you can delete an NVMe service, the administrative status must be down . Use the vserver nvme modify command to change the administrative status.
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver for the NVMe service.
cluster1::*> vserver nvme delete -vserver vs_1
Deletes the NVMe service on Vserver vs_1 .
