The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume recovery-queue recover
PDF of this doc site
Creating your file...
Your file is ready
Recover volumes from the recovery queue belonging to a Vserver
The volume recovery-queue recover
command recovers a volume from the recovery queue belonging to a Vserver.
This command will restore the volume with its previous access type and the volume will remain offline. This command will not restore the volume with its previous name, junction, LUN mappings, NVMe namespace mappings, quota policy rules and snapshot schedules. |
-vserver <vserver name>
- Vserver Name (privilege: advanced)-
This specifies the Vserver on which the volume is located.
-volume <volume name>
- Volume Name (privilege: advanced)-
This specifies the volume that is to be recovered.
The following example recovers a volume named vol1_1234 on a Vserver named vs1 from the recovery queue.
cluster1::*> volume recovery-queue recover -vserver vs1 -volume vol1_1234
