ONTAP commands
storage tape show-errors
Display tape drive errors
The storage tape show-errors command displays error information about tape drives attached to the cluster. By default, this command displays the following information about all tape drives:
  • Node to which the tape drive is attached
  • Device ID of the tape drive
  • Type of device(tape drive)
  • Description of the tape drive
  • Alias name of the tape drive
  • Tape drive errors
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Displays detailed information about tape drives on the specified node.
[-device-id <text>] - Device ID
Selects the tape drive with the specified device ID.
[-device-type <text>] - Device Type
Selects the devices with the specified type of tape drive.
[-description <text>] - Description
Selects the tape drives with the specified description.
[-alias-name <text>] - Alias Name
Selects the tape drive with the specified alias name.
[-wwnn <text>] - World Wide Node Name
Selects the tape drives with the specified World Wide Node Name.
[-wwpn <text>] - World Wide Port Name
Selects the tape drive with the specified World Wide Port Name.
[-serial-number <text>] - Serial Number
Selects the tape drive with the specified serial number.
[-error <text>] - Tape Drive Error Description
Selects the tape drives with the specified error string.
[-initiator <text>] - Initiator Port
Selects the tape drives with the specified initiator port.
The following example shows error information for all tape drives attached to cluster1.
cluster1::> storage tape show-errors
         Node: node1
    Device ID: 0d.125
  Device Type: tape drive
  Description: Hewlett-Packard LTO-5
        Alias: st0
Errors: hardware error; repair or replace tape drive
Node: node1
    Device ID: 2d.0
  Description: IBM LTO-6 ULT3580
        Alias: st2
Errors: -
The following example shows error information for tape drive sw4:2.126L1 attached to the node, node1.
cluster1::> storage tape show-errors -device-id sw4:2.126L1 -node node1
Node: node1
    Device ID: sw4:2.126L1
  Description: Hewlett-Packard LTO-3
        Alias: st3
Errors: -
