The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver cifs superuser delete
PDF of this doc site
Creating your file...
Your file is ready
Deletes superuser permissions from a CIFS account
The vserver cifs superuser delete
command removes the superuser privileges for the specified domain account in this Vserver. With superuser privileges, Data ONTAP bypasses some of the security checks.
-vserver <vserver name>
- Vserver (privilege: advanced)-
Vserver name.
-domain <CIFS domain>
- Domain (privilege: advanced)-
The domain name of accountname.
-accountname <CIFS account>
- User (privilege: advanced)-
The domain account name you want to remove superuser privileges.
The following example shows how to remove superuser privileges for ExampleUser in EXAMPLE domain for a Vserver vs1.
vs1::> vserver cifs superuser delete -domain EXAMPLE -accountname ExampleUser -vserver vs1
