Command reference
vserver cifs superuser delete
Deletes superuser permissions from a CIFS account
The vserver cifs superuser delete command removes the superuser privileges for the specified domain account in this Vserver. With superuser privileges, ONTAP bypasses some of the security checks.
-vserver <vserver name> - Vserver (privilege: advanced)
Vserver name.
-domain <CIFS domain> - Domain (privilege: advanced)
The domain name of accountname.
-accountname <CIFS account> - User (privilege: advanced)
The domain account name you want to remove superuser privileges.
The following example shows how to remove superuser privileges for ExampleUser in EXAMPLE domain for a Vserver vs1.
vs1::> vserver cifs superuser delete -domain EXAMPLE -accountname ExampleUser -vserver vs1
