The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver nfs storepool blocked-client flush
PDF of this doc site
Creating your file...
Your file is ready
Flush cached blocked client entries on the specified node
The vserver nfs storepool blocked-client flush
command flushes the storepool blocked client cache which allows the previously blocked specified clients to reconnect.
Node on which storepool blocked client cache is present
Client ip address
-node <nodename>
- Node (privilege: advanced)-
If this parameter is specified, the command is used to flush the storepool blocked client cache only in the specified node.
[-client-ip <IP Address>]
- Client IP Address (privilege: advanced)-
If this parameter is specified, the command is used to only flush the storepool blocked client cache associated with specified client IP.
The following example flushes all NFSv4 storepool blocked client caches present on node1.
cluster1::*> vserver nfs storepool blocked-client flush -node node1 Number of NFSv4.x blocked clients flushed on node "node1": 0. cluster1::*>
