The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
cluster identity show
PDF of this doc site
Creating your file...
Your file is ready
Display the cluster's attributes including Name, Serial Number, Cluster UUID, Location and Contact
The cluster identity show
command displays the identity information of the cluster.
The following example displays the cluster's UUID, name, serial number, location and contact information:
cluster1::> cluster identity show Cluster UUID: 1cd8a442-86d1-11e0-ae1c-123478563412 Cluster Name: cluster1 Cluster Serial Number: 1-80-123456 Cluster Location: Lab2 Cluster Contact: jsmith@example.com cluster1::>
