cluster identity show
Display the cluster's attributes including Name, Serial Number, Cluster UUID, Location and Contact
The cluster identity show
command displays the identity information of the cluster.
The following example displays the cluster's UUID, name, serial number, location and contact information:
cluster1::> cluster identity show Cluster UUID: 1cd8a442-86d1-11e0-ae1c-123478563412 Cluster Name: cluster1 Cluster Serial Number: 1-80-123456 Cluster Location: Lab2 Cluster Contact: jsmith@example.com cluster1::>
