ONTAP 9.10.1 commands
cluster identity show
Display the cluster's attributes including Name, Serial Number, Cluster UUID, Location and Contact
The cluster identity show command displays the identity information of the cluster.
The following example displays the cluster's UUID, name, serial number, location and contact information:
cluster1::> cluster identity show
Cluster UUID: 1cd8a442-86d1-11e0-ae1c-123478563412
          Cluster Name: cluster1
 Cluster Serial Number: 1-80-123456
      Cluster Location: Lab2
       Cluster Contact: jsmith@example.com
cluster1::>
