security ssh prepare-to-downgrade
PDF of this doc site
Creating your file...
Your file is ready
Downgrade the SSH configuration to be compatible with releases earlier than Data ONTAP 9.2.0.
This command downgrades the SSH configurations of all Vservers and the cluster to settings compatible with releases earlier than Data ONTAP 9.2.0. This command also disables the max-authentication-retry feature. You must run this command in advanced privilege mode when prompted to do so during the release downgrade. Otherwise, the release downgrade process will fail.
The following command downgrades the SSH security configurations of all Vservers and the cluster to settings compatible with releases earlier than Data ONTAP 9.2.0.
cluster1::*> security ssh prepare-to-downgrade
