lun igroup modify
Modify an existing initiator group
This command modifies an attribute for an initiator group. Currently, the only settable attribute is the operating system.
- -vserver <Vserver Name>- Vserver Name
Specifies the Vserver.
- -igroup <text>- Igroup Name
Specifies the initiator group whose attribute you want to modify.
- [-t, -ostype <Initiator Group OS Type>]- OS Type
Specifies the operating system that you want to modify. The operating system types of initiators are -
solaris
windows
hpux
aix
linux
netware
vmware
openvms
xen
hyper_v
- [-delete-on-unmap {true|false}]- Delete on Last Unmap
Specifies if this initiator group will be deleted automatically when no longer a member of a LUN mapping relationship.
- [-comment <text>]- Igroup Comment
Specifies the comment for the igroup you want to modify. If the comment string contains white space, it must be enclosed in double quotes. The limit is 254 characters. To clear the comment, specify the empty string enclosed in double quotes.
cluster1::> lun igroup modify -vserver vs1 -igroup ig1 -ostype windows
Changes the operating system to windows for initiator group ig1 on Vserver vs1 .
 PDFs
PDFs
