      network tuning icmp modify
Modify ICMP tuning options
This command displays options which can be used to fine tune icmp protocol behavior.
-node {<nodename>|local}- Node-
Sets this parameter to indicate on which node the ICMP tuning options are modified.
 [-is-drop-redirect-enabled {true|false}]- Drop redirect ICMP-
Sets this parameter to drop redirect ICMP message.
 [-tx-icmp-limit <integer>]- Maximum number of ICMP packets sent per second-
Sets the maximum number of ICMP messages including TCP RSTs can be sent per second.
 [-redirect-timeout <integer>]- Maximum seconds for route redirect timeout-
Sets this parameter to indicate the number of seconds after which the route is deleted. Value of zero means infinity. The default value is 300 seconds.
cluster1::> network tuning icmp modify -node node1 -is-drop-redirect-enabled false
