network tuning icmp modify
Modify ICMP tuning options
This command displays options which can be used to fine tune icmp protocol behavior.
-node {<nodename>|local}
- Node-
Sets this parameter to indicate on which node the ICMP tuning options are modified.
[-is-drop-redirect-enabled {true|false}]
- Drop redirect ICMP-
Sets this parameter to drop redirect ICMP message.
[-tx-icmp-limit <integer>]
- Maximum number of ICMP packets sent per second-
Sets the maximum number of ICMP messages including TCP RSTs can be sent per second.
[-redirect-timeout <integer>]
- Maximum seconds for route redirect timeout-
Sets this parameter to indicate the number of seconds after which the route is deleted. Value of zero means infinity. The default value is 300 seconds.
cluster1::> network tuning icmp modify -node node1 -is-drop-redirect-enabled false
