network tuning icmp modify
Modify ICMP tuning options
This command displays options which can be used to fine tune icmp protocol behavior.
-node {<nodename>|local} - Node
Sets this parameter to indicate on which node the ICMP tuning options are modified.
[-is-drop-redirect-enabled {true|false}] - Drop redirect ICMP
Sets this parameter to drop redirect ICMP message.
[-tx-icmp-limit <integer>] - Maximum number of ICMP packets sent per second
Sets the maximum number of ICMP messages including TCP RSTs can be sent per second.
[-redirect-timeout <integer>] - Maximum seconds for route redirect timeout
Sets this parameter to indicate the number of seconds after which the route is deleted. Value of zero means infinity. The default value is 300 seconds.
cluster1::> network tuning icmp modify -node node1 -is-drop-redirect-enabled false
