ONTAP commands
vserver nvme subsystem map remove
Remove a namespace map
The vserver nvme subsystem map remove command deletes an association on an NVMe namespace to an NVMe subsystem.
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver.
-subsystem <text> - Subsystem
Specifies the NVMe target subsystem.
-path <path> - Namespace Path
Specifies the path of the NVMe namespace. Examples of correct NVMe namespace paths are /vol/vol1/ns1 and /vol/vol1/qtree1/ns1 .
cluster::*> vserver nvme subsystem map remove -vserver vs_1 -subsystem sub_1 -path /vol/nsvol/namespace1
Removes the association on the NVMe namespace at the specified path to NVMe subsystem sub_1 on Vserver vs_1 .
