vserver nfs stop
Stop the NFS service of a Vserver
The vserver nfs stop command stops the NFS service on a Vserver to serve NFS clients. The Vserver must already exist.
-vserver <vserver name>- Vserver-
This parameter specifies the Vserver on which you want to stop the NFS service.
The following example stops the NFS service on a Vserver named vs0.
cluster1::> vserver nfs stop -vserver vs0
