job private resume
Resume a job
The job private resume command resumes a private job that was paused by using the job private pause command. Private jobs are affiliated with a specific node and do not use any cluster facilities, such as the replicated database.
Use the job private show command to view a list of paused private jobs that can be resumed.
-node {<nodename>|local} - Node (privilege: advanced)
Use this parameter to specify the node with which the paused private job is associated.
-id <integer> - Job ID (privilege: advanced)
Use this parameter to specify the numeric ID of the paused private job to be resumed. A job ID is a positive integer.
[-vserver <vserver name>] - Owning Vserver (privilege: advanced)
Use this parameter to specify the name of the Vserver that owns the job.
The following example resumes the paused private job that has ID 99 on a node named node2 :
cluster1::*> job private resume -node node2 -id 99
