job private show
Display a list of jobs
The job private show command displays information about private jobs. Private jobs are affiliated with a specific node and do not use any cluster facilities, such as the replicated database.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-inprogress ](privilege: advanced)
Displays the job ID, name, owning Vserver, and progress of each private job.
- | [-jobstate ](privilege: advanced)
Displays information about each private job's state, including the queue state, whether the job was restarted, and when the job has timed out.
- | [-jobuuid ](privilege: advanced)
Displays the ID, name, owning Vserver, and UUID of each private job.
- | [-sched ](privilege: advanced)
Displays the job ID, name, owning Vserver, and run schedule of each private job.
- | [-times ](privilege: advanced)
Displays the queue time, start time, and end time of each private job.
- | [-type ](privilege: advanced)
Displays the type and category of each private job.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node (privilege: advanced)
Selects the private jobs that match this parameter value. .
- [-id <integer>]- Job ID (privilege: advanced)
Selects the private jobs that match the ID or range of IDs that you specify.
- [-vserver <vserver name>]- Owning Vserver (privilege: advanced)
- [-name <text>]- Name (privilege: advanced)
- [-description <text>]- Description (privilege: advanced)
- [-priority {Low|Medium|High|Exclusive}]- Priority (privilege: advanced)
- [-schedule <job_schedule>]- Schedule (privilege: advanced)
- [-queuetime <MM/DD HH:MM:SS>]- Queue Time (privilege: advanced)
- [-starttime <MM/DD HH:MM:SS>]- Start Time (privilege: advanced)
- [-endtime <MM/DD HH:MM:SS>]- End Time (privilege: advanced)
- [-dropdeadtime <MM/DD HH:MM:SS>]- Drop-dead Time (privilege: advanced)
- [-restarted {true|false}]- Restarted? (privilege: advanced)
- [-state {Initial|Queued|Running|Waiting|Pausing|Paused|Quitting|Success|Failure|Reschedule|Error|Quit|Dead|Unknown|Restart|Dormant}]- State (privilege: advanced)
- [-code <integer>]- Status Code (privilege: advanced)
- [-completion <text>]- Completion String (privilege: advanced)
- [-jobtype <text>]- Job Type (privilege: advanced)
- [-category <text>]- Job Category (privilege: advanced)
- [-uuid <UUID>]- UUID (privilege: advanced)
- [-progress <text>]- Execution Progress (privilege: advanced)
- [-username <text>]- User Name (privilege: advanced)
The following example displays information about all private jobs on the local node:
cluster1::*> job private show -node local
Node: node1
                            Owning
Job ID Name                 Vserver    State
3      snap-hourly          cluster1   Queued
       Description: Auto-Snapshot
4      snap-daily           cluster1   Queued
5      snap-weekly          cluster1   Queued
6      sync task            cluster1   Queued
       Description: sync task
7      ldap-certs           cluster1   Queued
       Description: ldap resync
5 entries were displayed.
 PDFs
PDFs
