job private show
PDF of this doc site
Creating your file...
Display a list of jobs
The job private show
command displays information about private jobs. Private jobs are affiliated with a specific node and do not use any cluster facilities, such as the replicated database.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-inprogress ]
(privilege: advanced) -
Displays the job ID, name, owning Vserver, and progress of each private job.
[-jobstate ]
Displays information about each private job's state, including the queue state, whether the job was restarted, and when the job has timed out.
[-jobuuid ]
Displays the ID, name, owning Vserver, and UUID of each private job.
[-sched ]
Displays the job ID, name, owning Vserver, and run schedule of each private job.
[-times ]
Displays the queue time, start time, and end time of each private job.
[-type ]
Displays the type and category of each private job.
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node (privilege: advanced)-
Selects the private jobs that match this parameter value. .
[-id <integer>]
- Job ID (privilege: advanced)-
Selects the private jobs that match the ID or range of IDs that you specify.
[-vserver <vserver name>]
- Owning Vserver (privilege: advanced)-
[-name <text>]
- Name (privilege: advanced)-
[-description <text>]
- Description (privilege: advanced)-
[-priority {Low|Medium|High|Exclusive}]
- Priority (privilege: advanced)-
[-schedule <job_schedule>]
- Schedule (privilege: advanced)-
[-queuetime <MM/DD HH:MM:SS>]
- Queue Time (privilege: advanced)-
[-starttime <MM/DD HH:MM:SS>]
- Start Time (privilege: advanced)-
[-endtime <MM/DD HH:MM:SS>]
- End Time (privilege: advanced)-
[-dropdeadtime <MM/DD HH:MM:SS>]
- Drop-dead Time (privilege: advanced)-
[-restarted {true|false}]
- Restarted? (privilege: advanced)-
[-state {Initial|Queued|Running|Waiting|Pausing|Paused|Quitting|Success|Failure|Reschedule|Error|Quit|Dead|Unknown|Restart|Dormant}]
- State (privilege: advanced)-
[-code <integer>]
- Status Code (privilege: advanced)-
[-completion <text>]
- Completion String (privilege: advanced)-
[-jobtype <text>]
- Job Type (privilege: advanced)-
[-category <text>]
- Job Category (privilege: advanced)-
[-uuid <UUID>]
- UUID (privilege: advanced)-
[-progress <text>]
- Execution Progress (privilege: advanced)-
[-username <text>]
- User Name (privilege: advanced)-
The following example displays information about all private jobs on the local node:
cluster1::*> job private show -node local Node: node1 Owning Job ID Name Vserver State ------ -------------------- ---------- ----------- 3 snap-hourly cluster1 Queued Description: Auto-Snapshot 4 snap-daily cluster1 Queued Description: Auto-Snapshot 5 snap-weekly cluster1 Queued Description: Auto-Snapshot 6 sync task cluster1 Queued Description: sync task 7 ldap-certs cluster1 Queued Description: ldap resync 5 entries were displayed.
