ONTAP commands
job private show
Display a list of jobs
The job private show command displays information about private jobs. Private jobs are affiliated with a specific node and do not use any cluster facilities, such as the replicated database.
{ [-fields <fieldname>,…​]
| [-inprogress ] (privilege: advanced)
Displays the job ID, name, owning Vserver, and progress of each private job.
| [-jobstate ] (privilege: advanced)
Displays information about each private job's state, including the queue state, whether the job was restarted, and when the job has timed out.
| [-jobuuid ] (privilege: advanced)
Displays the ID, name, owning Vserver, and UUID of each private job.
| [-sched ] (privilege: advanced)
Displays the job ID, name, owning Vserver, and run schedule of each private job.
| [-times ] (privilege: advanced)
Displays the queue time, start time, and end time of each private job.
| [-type ] (privilege: advanced)
Displays the type and category of each private job.
| [-instance ] }
[-node {<nodename>|local}] - Node (privilege: advanced)
Selects the private jobs that match this parameter value. .
[-id <integer>] - Job ID (privilege: advanced)
Selects the private jobs that match the ID or range of IDs that you specify.
[-vserver <vserver name>] - Owning Vserver (privilege: advanced)
[-name <text>] - Name (privilege: advanced)
[-description <text>] - Description (privilege: advanced)
[-priority {Low|Medium|High|Exclusive}] - Priority (privilege: advanced)
[-schedule <job_schedule>] - Schedule (privilege: advanced)
[-queuetime <MM/DD HH:MM:SS>] - Queue Time (privilege: advanced)
[-starttime <MM/DD HH:MM:SS>] - Start Time (privilege: advanced)
[-endtime <MM/DD HH:MM:SS>] - End Time (privilege: advanced)
[-dropdeadtime <MM/DD HH:MM:SS>] - Drop-dead Time (privilege: advanced)
[-restarted {true|false}] - Restarted? (privilege: advanced)
[-state {Initial|Queued|Running|Waiting|Pausing|Paused|Quitting|Success|Failure|Reschedule|Error|Quit|Dead|Unknown|Restart|Dormant}] - State (privilege: advanced)
[-code <integer>] - Status Code (privilege: advanced)
[-completion <text>] - Completion String (privilege: advanced)
[-jobtype <text>] - Job Type (privilege: advanced)
[-category <text>] - Job Category (privilege: advanced)
[-uuid <UUID>] - UUID (privilege: advanced)
[-progress <text>] - Execution Progress (privilege: advanced)
[-username <text>] - User Name (privilege: advanced)
The following example displays information about all private jobs on the local node:
cluster1::*> job private show -node local
Node: node1
                            Owning
Job ID Name                 Vserver    State
3      snap-hourly          cluster1   Queued
       Description: Auto-Snapshot
4      snap-daily           cluster1   Queued
5      snap-weekly          cluster1   Queued
6      sync task            cluster1   Queued
       Description: sync task
7      ldap-certs           cluster1   Queued
       Description: ldap resync
5 entries were displayed.
