The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
job delete
PDF of this doc site
Creating your file...
Your file is ready
Delete a job
The job delete
command deletes a job. Use the job show command to view a list of running jobs that can be deleted.
-id <integer>
- Job ID-
The numeric ID of the job you want to delete. A job ID is a positive integer.
[-vserver <vserver name>]
- Owning Vserver-
Use this parameter to specify the name of the Vserver that owns the job.
The following example deletes the job that has ID 99:
cluster1::> job delete -id 99
