Command reference
job delete
Delete a job
The job delete command deletes a job. Use the job show command to view a list of running jobs that can be deleted.
-id <integer> - Job ID
The numeric ID of the job you want to delete. A job ID is a positive integer.
[-vserver <vserver name>] - Owning Vserver
Use this parameter to specify the name of the Vserver that owns the job.
The following example deletes the job that has ID 99:
cluster1::> job delete -id 99
