volume snapshot modify-snaplock-expiry-time
PDF of this doc site
Creating your file...
Modify expiry time of a SnapLock Snapshot copy
The volume snapshot modify-snapshot-expiry-time
extends snaplock expiry time of an existing Snapshot copy.
-vserver <vserver name>
- Vserver-
This specifies the Vserver that contains the volume on which the Snapshot copy is located.
-volume <volume name>
- Volume-
This specifies the volume where a Snapshot copy is to be located.
-snapshot <text>
- Snapshot-
This specifies the name of the Snapshot copy locked by SnapLock whose snaplock expiry time needs to be modified.
[-expiry-time {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm] | infinite}]
- SnapLock Expiry Time-
Specifies the new snaplock expiry that is applied to Snapshot copy locked by SnapLock.
If this option value is
infinite
, then a retention period that never expires is applied to the Snapshot copy.
The following example extends the retention period of a Snapshot copy snap1
to "03/03/2020 00:00:00"
cluster1::> volume snapshot modify-snaplock-expiry-time -vserver vs1 -volume vol1 -snapshot snap1 -expiry-time "03/03/2020 00:00:00" cluster1::>
The following example extends the retention period of a Snapshot copy snap2
to infinite
cluster1::> volume snapshot modify-snaplock-expiry-time -vserver vs1 -volume vol1 -snapshot snap2 -expiry-time infinite cluster1::>
cluster1::> volume snapshot show -vserver vs1 -fields snaplock-expiry-time vserver volume snapshot snaplock-expiry-time ------- ------ -------- ------------------------ vs1 vol1 snap1 3/3/2020 00:00:00 +05:30 vs1 vol1 snap2 infinite
