storage tape load-balance show
Displays the tape load balance configuration
The storage tape load-balance show command displays tape load balance settings for each node in the cluster.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects information about tape load balancing for the specified node.
[-is-enabled {true|false}] - Is Tape Load Balance Enabled
Selects information about load balance configuration as specified by enabled or disabled setting.
The following example shows the load balance setting for each node in the cluster:
cluster1::> storage tape load-balance show
Node                        Enabled
node1                       false
node2                       false
2 entries were displayed.
