storage tape load-balance show
Displays the tape load balance configuration
The storage tape load-balance show command displays tape load balance settings for each node in the cluster.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects information about tape load balancing for the specified node.
[-is-enabled {true|false}]- Is Tape Load Balance Enabled-
Selects information about load balance configuration as specified by enabled or disabled setting.
The following example shows the load balance setting for each node in the cluster:
cluster1::> storage tape load-balance show Node Enabled --------------------------- --------- node1 false node2 false 2 entries were displayed.
