volume file show-filehandle
Show the file handle of a file
This command requires a path to a file in a volume and displays the file handle information described below:
Vserver name
Path to the file
File handle flags
Snapshot ID of the file (snapid)
File ID
File handle generation number
File system ID (fsid)
Master data set ID (msid)
Data set ID (dsid)
If not logged in as a Vserver administrator, the command also requires a Vserver name.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver Managing Volume (privilege: advanced)-
This specifies the Vserver where the file resides.
[-path <text>]
- Path to File (privilege: advanced)-
This specifies the path to the file.
The following example displays the file handle information of a file named file1.txt
in the volume /vol/vol1
cluster1::> volume file show-filehandle -vserver vs0 -path /vol/vol1/file1.txt Vserver Path ---------------------- --------------------------- vs0 /vol/vol1/file1.txt flags snapid fileid generation fsid msid dsid ------- ------ --------- ---------- ---------- ------------ ------------ 0x0 0 0x60 0x206b6 0x402 0x80000402 0x402
