system services firewall show
Show firewall status
The system services firewall show command displays firewall configuration and logging information. If the command is issued without any parameters, it displays information about all nodes in the cluster. You can also query specific nodes for their firewall information by running the command with the -node parameter.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects information about the firewall settings on the node you specify.
 [-enabled {true|false}]- Service Enabled-
Selects information about the nodes with the firewall enabled ("
true") or disabled ("false"). [-logging {true|false}]- (DEPRECATED)-Enable Logging-
This parameter is deprecated and may be removed in a future version of Data ONTAP. Selects information about the nodes with firewall logging enabled ("
The following example displays information about firewall configuration for all nodes in the cluster:
cluster1::> system services firewall show Node Enabled Logging -------------- ------- ------- node0 true false node1 true false node2 true false node3 true false 4 entries were displayed.
