Command reference
system services firewall show
Show firewall status
The system services firewall show command displays firewall configuration. If the command is issued without any parameters, it displays information about all nodes in the cluster. You can also query specific nodes for their firewall information by running the command with the -node parameter.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects information about the firewall settings on the node you specify.
[-enabled {true|false}] - Service Enabled
Selects information about the nodes with the firewall enabled ("true ") or disabled ("false ").
The following example displays information about firewall configuration for all nodes in the cluster:
cluster1::> system services firewall show
Node           Enabled
node0          true
node1          true
node2          true
node3          true
4 entries were displayed.
