ONTAP commands
vserver show-protocols
Show protocols for Vserver
The vserver show-protocols command displays the running protocols on a given Vserver.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver>] - Vserver
If this parameter is specified, the command displays the allowed set of protocols for the specified Vserver.
[-protocol {nfs|cifs|fcp|iscsi|ndmp|nvme}] - Protocols
If this optional parameter is specified, the command displays all the Vservers configured with the specified protocols.
The following example displays the protocols configured for Vserver vs1.
cluster1::> vserver show-protocols -vserver vs1
  Vserver: vs1
  Protocols: nfs, cifs
